How to Rip DVD for NDS with DVDFab DVD Ripper?
05/27/2020
NDS is not only a handheld game console but also a video player. You can watch your DVD movie on your NDS by converting the DVD into the format supported by NDS. DVDFab DVD Ripper is an excellent DVD to NDS ripper, which can convert DVD to NDS quickly and effortlessly. Now let's have a look at how to use DVDFab DVD Ripper to rip DVD for NDS.
Step 1: Load the source
Run DVDFab 10, go to Ripper module and load the source.
Step 2: Choose the NDS profile
Navigate to the profile library on the top left corner of the main interface and choose Device> Others> NDS.
Step 3: Customize your video
After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio track, subtitles, and define the name of the chosen title. If you want, you can also click the “Advanced Settings” icon to customize your settings and click the “Editor” icon to edit the video.
Step 4: Select a directory and start the ripping process
Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the process of ripping DVD to NDS.
Then the only thing you need to do is to wait. You can get the converted video in a few minutes.
This tip shows you how to convert DVD to video, but how to rip Blu-ray to video format? To convert Blu-ray to video, you can use DVDFab Blu-ray Ripper. It is a full-featured Blu-ray ripping tool that can rip Blu-ray to various formats easily and quickly.
